قديم 21-09-2011, 09:45 AM
الصورة الرمزية AbOnOrA
Aِِbo(Nora&Islam&Judy)
Wael Magdy Salah
من انا؟: ابو نورا واسلام
التخصص العملى: IT Consultant
الموقع: ام الدنيا مصر
افتراضي رينجات فوانيس ملتى كلر ((وهمية))
Umnitza Predator OrionTM V2 MC
CLASS LEADING FEATURES: (not available on any other competing product)
First ever multi-color Umnitza Orion Angel eyes. The first angel eyes product on the market that allows the customer to change the color of their angel eyes on the fly, while driving, or at a show. This product will allow the user to change to different modes, different colors, and even different themes all from the comfort of their own car via color changing LED switch.
Multi-Color doesn't have the same problems as other LED products, the color transitions are smooth and immediate and new "modes" are being developed to easily upgrade in the future if you would like more choices.
4 total modes
* individual color selected (red/green/blue/yellow/amber/white/blue-white/purplish)
* individual colors fade between each other
* individual colors blink between each other
* locked in WHITE
Mode selection is done by switch, with lock out control for white mode (2 button)
This product incorporates the brightest Light Emitting Diode technology currently available today. The LED is used in a variety of applications due to it's longevity, durability, and cold weather instant operability characteristics. The Predator Orion, the only product with the reflective backing to prevent bleeding of the light in all directions points the light output in the direction of the only place that matters - out.
Predator OrionTM & Orion IITM are daytime visible, mounted inside a high polish crystal light enhancing cover that is the same size as the OEM angel eyes, just brighter. The high quality wiring harness included was the first to be fully insulated and provides you with both a fused primary trigger and a secondary trigger for automatic dimming (fade/on & fade/off) functionality.
Comparison of leading competitors:
Mycarr vs Orion V2 - CLICK THIS TO SEE COMPARISON
Photos of Orion -Â CLICK FOR PHOTO THREAD
Orion V2TM MC has the following most important features:
Chromium backing
Why settle for any bleeding of light out the back of your rings. Get ones that are crisp and clean.
 LED ARRAY
High Output 10000mcd LEDs. First of their kind on the market.
Surface Mount LED with over 175 degree output.
Multi-Stage Clipping System
That's right, no need to decide for only 2 clips. Now you have the ability to install the clip in ANY configuration, 2 clicks? no problem, 3 clicks? no problem? 4 clicks? no problem. This solves the one issue that facelifted sedans (02-05 E46 3-series sedans) with trim piece fitment.
Carry-Over Features
  • Lifetime Warranty
  • Remote Fade/On Fade/Off
  • PolyCarbonate UV Coated Rings
  • The Best fitting product
  • 100K Hours Expected Life
  • Easier Installation than ANY OTHER KIT
Product Description (may describe some optional equipment):
Continuing our class and industry leading technological development allowed us to produce the pinnacle of angel eyes for your car. The Predator OrionTM product line allows you to retain the classy OEM look (with OEM Series) of the original halos from the E39 (5-series) but just raise the bar on brightness and provide the captivating powerful halos you want.
  • 4 Halos - The brightest halos ever produced.
  • 1 full wiring harness
  • Multi-Stage Clipping System (why settle for only 2, when you can have MANY)
  • Lifetime warranty
  • Online Instructions - Linked Install Resources Section
  • All Hardware and Installation Included
  • Headlights & Car Sold Separately
Benefits:
  • Updated Look
  • Allows you to clear or black out your turn signal at the same time
  • Can be wired as DRL (daytime running lights)
  • Significant improvement in visual appeal of car
  • Very Bright/Neo Modern Look
  • Pure White (custom colors available on special order only)
  • No Light Box
  • Easy fit
  • 2X As bright as the Competition -Â
  • Works with All Auto Leveling and Adaptive Lights - Universal Fit
Install Tips:
  • PRETEST the bulbs, do not flex the bulbs in any way.
  • Ensure secure connections to and from the headlight.
Application (Please consult your owner's manual for your application fitment type):
All 1999-2005 Sedans
All 2000-2003 Coupes (with non-sealed lights)
All 2000-2006 M3 (all lights similar to 2000-2003 Coupe Lights)
All 1995-2001 7-series
All 1997-2000 5-series
All 2001-2002 X5
All 1992-1999 3-series (E36) with Euro Headlights
2004-2006 3-series Coupe - COMING SOON -
Fits All Halogen, Xenon, BiXenon, and Adaptive Xenon Lights
Comparison of Chromium and Orion
DETAILED Photos
1.
  • The rear is covered with a full backing that holds the LED system in place. There are no external solder points on the back.
  • The covering serves as an insulation so there are no exposed points of power that could potentially lead to a short in the circuit.
  • The photo shown has additional pads that will not be on a finished ring that you receive, they were originally put there to stabilize the ring, but that is not necessary giving some proprietary mounting techniques being used.
  • The clipping system is designed to clip onto all types of headlights. The multiple teeth allow you to have the proper fit no matter what application
  • It's length is sufficient for all applications
  • The clips are very high tension, meaning that once they hold onto something, they don't let go. In the past, depending on how you installed the products, you might have a clip releasing from the ring itself. That will be nearly impossible with this product.
  • Also note that the cover discussed in the previous photo is visible here for great "clarity" of what was discussed earlier.
  • Please notice that there is NO exposed wiring
  • Please also notice that the ring goes all the way to the top of the ring, it does not break 3/4 of the way up and it does not have an exposed parts other than the ring itself
  • This is most important part of the rings here - it's CLEAR
  • Also please notice the slim profile of the LEDs so that they are not visible when off.
 <-- for video
Â
Â
Comparison Video of All Three Products:
Â
Drive By Video (PLEASE WATCH IN HIGH QUALITY)
Â
Â
اخر موضوعاتى
قديم 21-09-2011, 12:16 PM
الصورة الرمزية dr_eslam_66
dr_eslam_66 dr_eslam_66 غير متواجد حالياً
من انا؟: أنا شاب ولاكن عمري ألف عام أخرس وقلبي مليان كلام
التخصص العملى: مهندس مدني
هواياتي: --------
الموقع: الإمارات
dr_eslam_66 has a reputation beyond reputedr_eslam_66 has a reputation beyond reputedr_eslam_66 has a reputation beyond reputedr_eslam_66 has a reputation beyond reputedr_eslam_66 has a reputation beyond reputedr_eslam_66 has a reputation beyond reputedr_eslam_66 has a reputation beyond reputedr_eslam_66 has a reputation beyond reputedr_eslam_66 has a reputation beyond reputedr_eslam_66 has a reputation beyond reputedr_eslam_66 has a reputation beyond repute
افتراضي رد: رينجات فوانيس ملتى كلر ((وهمية))
إيه الحلاوة دي أنا مش مصدق عنيا أ،ا حاسس إني بقيت من العصر الحجري فجأة وأنا لسة صغنن ياخواتنا.
تسلم إيدك يا أبو نورى على مثل هذا الخبر المتميز. تفتكر في يوم من الأيام ممكن نلاقي حاجة زي دي بتباع في المحلات عادي في مصر.
قديم 26-09-2011, 01:15 AM
الصورة الرمزية khaled_1993m
khaled_1993m khaled_1993m غير متواجد حالياً
من انا؟: DR. Khaled Hussein Isamil
التخصص العملى: طالب طب
الموقع: Alexandrie
khaled_1993m has much to be proud ofkhaled_1993m has much to be proud ofkhaled_1993m has much to be proud ofkhaled_1993m has much to be proud ofkhaled_1993m has much to be proud ofkhaled_1993m has much to be proud ofkhaled_1993m has much to be proud ofkhaled_1993m has much to be proud ofkhaled_1993m has much to be proud of
بصراحة حاجات جامدة اوي بس هل ممكن الاقيها هنا في مصر ؟
شباب و قوة و غرور و فتنة و تسويف في التوبة حتي جاءت لحظات الوداع الاخيرة
قديم 26-09-2011, 01:24 AM
walidelwahsh
:craz yW14:
قديم 26-09-2011, 01:38 AM
الصورة الرمزية crime
crime crime غير متواجد حالياً
من انا؟: متخصص توظيف سيارات وومركز خدمه معتمد كيا
التخصص العملى: مروج سيارات للسفارات وشركات السياحه والهيئات الحكوميه
هواياتي: .جديد السيارات .الكتب سماع القران الكريم
الموقع: القاهره
crime has a reputation beyond reputecrime has a reputation beyond reputecrime has a reputation beyond reputecrime has a reputation beyond reputecrime has a reputation beyond reputecrime has a reputation beyond reputecrime has a reputation beyond reputecrime has a reputation beyond reputecrime has a reputation beyond reputecrime has a reputation beyond reputecrime has a reputation beyond repute
عقدتنى يا ابو نورا
الساعة الآن 11:02 AM.
