قديم 31-10-2012, 07:55 PM
منقول سويفت +HHO
Tell me if I'm wrong: 0,5 HHO LPM x Litres of engine capacity 3,5L=1,75 HHO LPM production ... minimum for iddleg? Then suggestion for driving is doubleing it to 3,50 HHO LPM ... yes?
Showing a new alternator bought for 140 amp to replace the 55 amp stock had to switch the wheels from the stock to the new one to get it to line up with the belt
Hho project geo metro 91
The belt I used for my new High amp Alternator is 13/32" x 34" OC you will also need to bore out one of the bracket holes just a little bit and buy a nut for that bolt that goes to it and with the belt like that you may want to buy and adjust able bracket to go on the top because it will squeal alot until the belt has heated up i havent bought a new top bracket for it yet but i used some thick rubber straps and have it pulling the alternator from the top to provide extra tension
قديم 02-11-2012, 03:59 PM
مميز رد: سويفت +HHO
DR\nktis, Vanditta
سويفت
الساعة الآن 01:49 AM.
