العودة   مصر موتورز مجتمع السيارات > منتدى الصيانة و اﻹصلاحات > منتدى الصيانة العام > مراكز الصيانة
مراكز الصيانة كل ما يتعلق بمراكز الصيانة و ورش الإصلاح و تجارب الأعضاء معها
مشاهدة نتائج الإستطلاع: رأيكم فى المنتج
ممتاز 0 0%
جيد 0 0%
عادى 0 0%
المصوتون: 0. أنت لم تصوت في هذا الإستطلاع
قديم 15-03-2013, 07:53 PM
mostafaatoz mostafaatoz غير متواجد حالياً
mostafaatoz is on a distinguished road
اعلان جهاز kwp2000 plus لبرمجة كنترول السيارات
للبيع جهاز kwp2000 plus لبرمجة كنترول السيارات بجميع الكابلات
مواصفاتة مع العلم الجهاز بالكرتونة محمد صالح 01065023612
Product Description
KWP2000+ ECU Plus FlasherFunctions:
This Kit can be used to read and write flash dumps of the most recent ECU's
It is very easy to use - You need only a PC with Windows and a USB port.
Petrol Vehicles (Naturally Aspirated)
Remapping a petrol engine ECU will increase 10 - 15% BHP depending on exact specification, the engine will also be more responsive on initial acceleration and produce more torque (up to 20%) through out the entire rev range, giving more response on lighter throttle.
Petrol Vehicles (Turbo)
Remapping a petrol turbo engine ECU will increase 20 - 30% BHP depending on exact specification, the engine will be significantly more responsive with power coming in immediately relative to throttle input with no lagging at higher revs. This large increase in power & torque gives far more flexibility in all gears and reducing the need to shift gear unnecessarily to overtake safely and quickly.
Diesel Vehicles (Turbo)
Remapping a diesel turbo engine ECU will increase 30 - 50% BHP and 60 - 75% torque depending on exact specification, diesel engines give the most impressive power and torque gains available. Extra power is gained through out the entire rev range and under all load conditions; the turning force gained from these engines is immense. This really is the best way of changing your car without having to change your car.
Specification:
Connects to USB
Supports high speed ECU flashing
Led Indications for USB-power/CAR-power/rx/tx
Can read and write a lot more ECU's than the normal KWP2000 interface
A. Read and analys your current ECU software;
B.Upgrad the ECU software with a re-mapped file ;
C.Repair ECUs with software problems or corruption.
How do you use the KWP2000 PLUS?
A: You need a computer. Installing KWP2000 Plus software.
B: Connect USB cable to your PC;
C: Connect to your car via standard 16-pin OBD2 connector;
D: Supports high speed ECU flashing
E: Led indications for USB-power Car-power/rx/tx
F: Support KWP2000+ software and other KWP/ ISO software
How to Read and Write data?
to Read to Write
- Click read button to read out the original data
- Click write button and select the file you want to write
- Save the file to you HD, edit or forward it -Follow the instructions on screen
- switch off ignition and wait 10 seconds
Package Contains:
• KWP2000 Plus device
• USB A/B connection cable
• OBD2 connection cable
• 38 pin Mercedes connection cable
• 20 pin BMW connection cable
• female banana cable
قديم 04-08-2013, 03:42 AM
samehlila samehlila غير متواجد حالياً
من انا؟: نائب مدير ادارة المعلومات - الهيئة العامة للتأمين الصحي - فرع البحيرة
التخصص العملى: مهندس كمبيوتر
هواياتي: السيارات و الاجهزة الالكترونية
الموقع: البحيرة
samehlila has much to be proud ofsamehlila has much to be proud ofsamehlila has much to be proud ofsamehlila has much to be proud ofsamehlila has much to be proud ofsamehlila has much to be proud ofsamehlila has much to be proud ofsamehlila has much to be proud of
افتراضي رد: جهاز kwp2000 plus لبرمجة كنترول السيارات
لو سمحت عايز اعرف السعر كام
و الف شكر
امتلك ماشئت ستذهب كما جئت
قديم 04-08-2013, 12:54 PM
الصورة الرمزية romeoalmansour
التخصص العملى: Engineer
هواياتي: reading and reading
الموقع: cairo
متابع .............
الله العظيم أعلي وأعلم
الساعة الآن 06:18 AM.
