العودة   مصر موتورز مجتمع السيارات > السيارات الأوروبية > فيات FIAT > ألفا روميو ALFA ROMEO
ألفا روميو ALFA ROMEO احدى شركات مجموعة فيات الايطالية وتمثل الجناح الرياضى فى الشركة
قديم 02-06-2012, 10:29 PM
افتراضي رد: Twin Spark engine!!
videos
http://youtu.be/xacnK8u6Y8A
http://youtu.be/Q0pQ2zcPXfs
Hisham.Elgazzar
قديم 30-06-2012, 11:31 PM
مميز رولمان بلى بديل جلب البنوز والسبايك !!: رولمان بلى للكرنك : Twin Spark engine!!
The crankshaft main bearings are regular ball bearings
well…
The crankshaft needs to be completely dismantled in a press to change the bearings. Actually you cannot see the connection rod bearings or the connection rod pin condition before you dismantle the shaft. The new bearings (and new pins if necessary) are also pushed to correct place in a press. After that the whole axle is put together again in a press.
This connection rod pin is clearly worn and needs to be replaced:
Above: The small picture shows the original roller bearing (with cast aluminium body) which were not very reliable on the long run. These are no-longer availlable, which requires that different type of bearing is used:
Main picture, from left, is the new connection rod pin (the center has bigger diameter to accommodate the new bearing). At center is the new bearings inner race and on the right the new needle-type roller bearing. This bearing has bigger diameter on the outside than the old one, so the connection rod big end needs some grinding.
The crankshaft main bearings are regular ball bearings and are readily availlable.
Pictures above: When the axle has been put together, it needs to be straightened (trued?). Straightening is a process of measuring the axle in a jig and hitting it with a hammer to eliminate the “wobble”. The factory tolerance for straightness measured as above, is less than 5/100 millimeter.
Here’s Lasse demonstrating the surgically precise hammer blows! Don’t try this at home!
Really, this is best left to the experts.
And remember: Never drop the crankshaft! The odds are, it will not be straight afterwards…
A few pics of the Saab Sport crankshaft I recently managed to get hold of:
On the left the “counterweight” or limput (“loafs” as we call them) of the sport-type and on the right the regular one. The sport axle has more mass than the regular one and the fully round “loafs” ensure better balance of the whole crankshaft enabling higher revolutions.
The bigger “counterweights” also take up more space in the crankcase, which results in higher pressure in the cylinder (more mixture). This gives you more power.
The Sport crankshaft also has better crankcase chamber-to-chamber sealing (see the sealing rings on both sides of the main bearings.
Above the full axle, very easy to identify by the fully round “loafs”.
Needle Roller Cage Assemblies for Connecting Rod
NTN Develops an Environmental Friendly Low Friction Needle Roller Bearing For Automotive Engines
Improves Automotive Fuel Efficiency by 3% and Makes Oil Pumps
and Starters More Compact and Light Weight
NTN Corporation (NTN) has developed Low Friction Needle Roller Bearings for automotive crankshaft and camshaft support applications. These bearings reduce torque considerably when compared to conventional plain bearings.
In recent years, engine oil viscosity has become lower to help reduce friction and improve fuel efficiency. In light of this, the use of rolling bearings instead of plain bearings has been considered to help reduce friction in the engine shaft support applications.
However, it is impossible to mount normal rolling bearings in these applications. Because of the crank arm and cam on the crankshaft and camshaft, only split type bearings with small cross-sectional heights will work. There have been no rolling bearings available to meet these needs. For this application, until now, either split type plain bearings have been used or the aluminum housing and shaft were placed directly in sliding contact.
In response to this, NTN has developed a split type rolling bearing for these two applications. NTN's newly developed Low Friction Needle Roller Bearings have a small cross-sectional height and can be easily mounted on the crankshaft and camshaft, contributing to increased automotive fuel economy and a more compact design.
For crank-shaft support applications:
Both the outer ring and the cage are split into two pieces. NTN's new split technology has made possible a high precision outer ring with a small cross-sectional height of 2mm. NTN's engine bearing technology also improves the cage's anti-seizure property and strength.
For cam-shaft support applications:
The drawn-cup outer ring is split into two pieces and the plastic cage is one piece but cut at one place. The use of a split drawn-cup made it possible to decrease the outer ring cross-sectional height to 0.6mm, which contributes to space reduction. Also, the outer ring strength was increased by optimizing its configuration using FEM analysis.
[Features: (compared with plain bearings)]
(1)Startup torque reduced by approximately 90%(2)Rotational torque reduced by approximately 50%(3)Increased vehicle fuel efficiency by approximately 3%
(measured by "10.15" gas emission test run mode)(4)Making engine oil-pump and starter more compact and light weight
(VA/VE can be expected)
[Contact]
  • Planning and Marketing Department, Automotive Sales Headquarters
    Phone: 03-5487-2814
[Photos]
Crankshaft low frinction needle roller bearing
Camshaft low friction needle roller bearing
[Advantages]
[How it Works]
(1)For crank-shaft support applications: Outer ring sectional height decreased to 2mm by NTN's new production method
to split outer ring ⇒ Contributing to space reduction
Cage anti-seizure property and strength improved by NTN's engine bearing technology (2)For cam-shaft support applications: Outer ring sectional height decreased to 0.6mm
by using press formed drawn-cup outer ring ⇒ Contributing to space reduction
Outer ring strength improved by optimum design using FEM analysis (2)For cam-shaft support applications: Outer ring sectional height decreased to 0.6mm
[Performance:
(Measured torque value, in comparison with plain bearing)]
·Startup torque : 90% less·Rotating torque : 50% less
crank and inspected the 5 roller bearings.
التعديل الأخير تم بواسطة cars admire ; 30-06-2012 الساعة 11:46 PM
قديم 01-07-2012, 12:21 AM
من انا؟: الفقير إلى الله
اى موتور منهم مناسب لعربيتى
واهى كلها فيات محدش هيتكلم ف المرور؟
قديم 01-07-2012, 12:43 AM
حصرى ده وش اسبراتير ال 4 سلندر 2 بوجيه للبستم الواحد لو اتكسر ومعرفتش تجيبه العربية هتقف !!!
alfa romeo 75 twin spark
Alfa Romeo 75 2.0 Twin Spark
موديلات الكربراتير بلاش الانجكشن !!!!!!!!!!
1992 Alfa Romeo 75 2.0TS (Turbo)
Electric turbo conversion!
Odd arragement for the twin spark thing too, with two distributors
Marelli distributor for use in Alfa twin spark engine.
فى منه موديل ب 2 اسبراتير بلاش منه برضه !!
مكان الاتنين بوجيه للبستم الواحد
فى منه 6 سلندر 3000 سى سى لو حبيت
قديم 01-07-2012, 05:17 PM
الموقع: طنـ بلد الاونطه ـــطا
جامد اووووووووووووووووى
شكلى لا هظبط ولا حاجه
انا انزل اشترى موتور من دول بالفتيس واسقط عندى وانتهينها
دا لينك اولتراس فيات 132
دا لينك صفحتى على الفيس بوك
spark, twin
الساعة الآن 12:59 PM.
