قديم 24-01-2009, 08:06 PM
الصورة الرمزية Semsem999999
Semsem999999 Semsem999999 غير متواجد حالياً
Semsem999999 has a reputation beyond reputeSemsem999999 has a reputation beyond reputeSemsem999999 has a reputation beyond reputeSemsem999999 has a reputation beyond reputeSemsem999999 has a reputation beyond reputeSemsem999999 has a reputation beyond reputeSemsem999999 has a reputation beyond reputeSemsem999999 has a reputation beyond reputeSemsem999999 has a reputation beyond reputeSemsem999999 has a reputation beyond reputeSemsem999999 has a reputation beyond repute
افتراضي رد: استفسار عن الفئة C180
طييب يا جماعة أي صور أي مواصفات أي حاااااااااااااااااااااااا اااجه نبل بيها ريقنا ؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟ ؟
قديم 24-01-2009, 09:28 PM
الصورة الرمزية ahmed_kamel
ahmed_kamel ahmed_kamel غير متواجد حالياً
التخصص العملى: مهندس معماري
الموقع: المعادي
ahmed_kamel has a reputation beyond reputeahmed_kamel has a reputation beyond reputeahmed_kamel has a reputation beyond reputeahmed_kamel has a reputation beyond reputeahmed_kamel has a reputation beyond reputeahmed_kamel has a reputation beyond reputeahmed_kamel has a reputation beyond reputeahmed_kamel has a reputation beyond reputeahmed_kamel has a reputation beyond reputeahmed_kamel has a reputation beyond reputeahmed_kamel has a reputation beyond repute
عيني ليك ياباشا بكره بعد الشغل يعني على بليل إن شاء الله حتلقى فيه موضوع عن C180
قديم 24-01-2009, 09:39 PM
دي تصبيره لحد ما مهندس احمد ينزل موضوعه الجامد
C-Class Saloon dimensions
Cylinder arrangement/number R4 عدد السيلندرات
Displacement (cc) 1597السعه
Rated output (kW [hp] at rpm) 115 [156]/5200 القوه
Rated torque (Nm at rpm) 230/2800–4600 العزم
Compression ratio 9.3:1 نسب الانضغاط
Acceleration 0-100 km/h (s) 9.5التسارع
Top speed (km/h) 230السرعه
Power transmission
Drive system Rear drive نظامر الجر
Transmissions 6-speed manual transmission علبه التروس
Mechanical transmission ratios 4.46/ 2.61/ 1.72/ 1.25/ 1.00/ 0.84/ R 4.06 نسب التروس
Automatic transmission ratios
Final drive transmission ratio 2.87النسبه النهائيه
Fuel and consumption [3]
Tank capacity/with reserve (l) 66/8 سعه الخزان
Fuel consumption, urban (l/100km) 9.2–9.5 استهلاك الوقود (داخل المدينه)
Fuel consumption, extra-urban (l/100km) 5.0–5.3 استهلاك الوقود
Fuel consumption combined (l/100km) 6.5–6.8 متوسط الاستهلاك
CO2 emissions (g/km) combined 156نسب الانبعاثات
Cd value 0.25معرفش
Emission class EU4 الترتيب الاوروبي للنظام البيئي ( متهيألي )
Chassis (standard) & wheels
Front axle 3-link suspension المحور الامامي
Rear axle Multilink ind susp المحور الاخلفي
Suspension, front/rear Coil spring/coil spring نظام التعليق
Front tyres/wheels 195/60 R 16 الاطارات امامي
Rear tyres/wheels 195/60 R 16 الاطارات خلفي
Steering Rack-and-pinion steering التوجيه
Front brakes Disc brakes, internally ventilated فرامل اماميه
Rear brakes Disc brakes فرامل خلفيه
Dimensions & weights
Kerb weight/payload capacity (kg) [4] 1465/485 الوزن / السعه
Perm. GVW (kg) 1950وزن اجمالي
Maximum roof load (kg) 100تحميل اعلا السقف
Boot capacity (VDA) (I) 475حجم الشنطه
Turning circle (m) 10.84قطر دوران
من تواضع لله رفعه
The ultimate car
would be designed by Italians
engineered by Germans
built by Japanese &
التعديل الأخير تم بواسطة sam ram ; 24-01-2009 الساعة 09:41 PM
قديم 24-01-2009, 10:28 PM
الموقع: المعادي
وهيه ديه التصبيره في نظرك
إنت جبت كل المعلومات اللي تهم الراجل عن السياره يعني ملخص أي موضوع ممكن الواحد يكتبه وكمان إتحط في جدول زي ما تكون جدول تشطيبات لوحه أو مقايسه كاملة البنود وكمان متسعره ptmnlo123per171
عموما إنت بتصعب علينا المهمه عشان سمسم حنحاول ياسمسم نجيب معلومات مفصله عن كل النقاط المهمه اللي حطها حبيبنا الحاج سامح
وربنا يستر ومايطلعش الموضوع اللي حعمله مكسح ptmnlo123per1146
قديم 24-01-2009, 11:03 PM
المشاركة الأصلية كتبت بواسطة ahmed_kamel مشاهدة المشاركة
لا والله ياريس ... دي المعلومات اللي لقيتها على الموقع الرسمي المصري
http://www.mercedes-benz.com.eg/
ولما لقيت طلب استاذ اسلام قلت انزلهم ويدوبك ترجمت الجدول وعقبال ما دخلت انزلهم لقيت مشاركتك يا ريس .... ptmnlo123per1127
فقلت يبقوا تصبيره لحد ما تجهز موضوعك الجامد
بس هي فعلا فيها نافيجيشين و اي درايف واوتو .... معقوله الكلام ده ...
من تواضع لله رفعه
The ultimate car
built by Japanese &
الساعة الآن 02:28 PM.
