قديم 19-09-2013, 01:49 PM
الصورة الرمزية romeoalmansour
التخصص العملى: Engineer
هواياتي: reading and reading
الموقع: cairo
افتراضي رد: عمرات (اصلاح) محركات السيارات
Fuel Injector Balance Testing
Preliminary Checks
Verify spark or lack of spark available at each cylinder
Verify fuel pressure and condition of fuel supply system
Injector Balance Test Procedure
Connect a fuel pressure gauge to the fuel rail pressure connection
Connect a Scan Tool, turn the to "ON" and Select Special Functions, Fuel System - Injector Balance Test
Select injector #1; the fuel system will prime. Record the initial pressure reading immediately after the fuel pump shuts off
Press the soft key to pulse the first injector. Record the 'Pressure After Pulse' reading immediately after the injector stops pulsing
Select and test each remaining injector. Be sure to record the Initial Pressure reading after each fuel system prime
Injector Balance Test Analysis
Subtract the 'Pressure After Pulse' reading from the Initial Pressure reading for each cylinder, record as Subtracted Value
Identify and record the 'Maximum Subtracted Value' and the 'Minimum Subtracted Value'
Subtract the Minimum Reading from the Maximum Reading to obtain Max Difference
If the Max Difference is less than 20 kPa (2.9psi), the injector are all flowing about the same and should not be replaced
If the Max Difference is greater than 20 kPa (2.9psi), you have one or more faulty injector(s). Replace the injector that appears to be different than the rest (Injector #4 in the example above). Repeat the balance test with the new injector to make sure that Max Difference is now less than 20 kPa (2.9psi
الله العظيم أعلي وأعلم
قديم 19-09-2013, 04:46 PM
الصورة الرمزية adham.com
دة اسمة ميكرومتر اقطار داخي او خارجي
ورق الفلر بيقسم الملي الي 100 جزء
اما الميكرومتر بيقسم الملي الي 1000 جزء
قديم 19-09-2013, 04:47 PM
المشاركة الأصلية كتبت بواسطة romeoalmansour مشاهدة المشاركة
معظم القياسات اللي حضرتك بتعملها او عايز تعملها كنا بعملها في المراكز في الامارات بس بسهولة جدا وبدون ادوات كتير كنا نفك الموتور حته حته ونحط قطع قصدير ونجمع الموتور بالكامل تاني ونربط بربط عزم معين ونفك ثم نقيس تخانه القصدير ومنها نعرف فيه تاكل ولازم ملو وخراطه او تغيير
و الله إنت نجم كبير فعلن
الفكرة بتاعت القصدير دي حلوة اوي و مش مكلفة و بدون أدوات
ماجاتش علي بالي للأسف
و انا خلاص قفلت الموتور بدون ما اعمل الكلام دة .. بإعتبار ان السبيكة لسة حالتها كويسة و رقمها 010 يعني الكرنك إتخرط مرة تقريبا
فتوكلت علي الله و قفلت و دورت و الحمد لله مفيش اي ترزيع في المكنة
ملحوظه هامه :- بخصوص جلد الصباب وكمان خرطوم الفايز
لو فيه مشكلة من او في الشنبر تلاقي دخنه في خرطوم الفايز - والدخنة دي ملهاش علاقة بجلد الصباب
والله اعلي واعلم
معلومة جديدة أول مرة اعرفها و كويسة
فعلن ممكن الواحد يدور الصبح مثلا و يلاقي دخنة و لكن بتروح بعد التسخين و بتمشي عادي خالص
في حالة لو الشنبر كويس أو جديد يعني
هنا بقي يظهر السؤال ازاي افرق بين تشخيص جلد الصباب وبين الشنبر
سؤال رائع
زي ما قلت قبل كده
جلد الصباب بيلم زيت عليه عشان كده الدخنة بتظهر اول ما تدور الصبح وتختفي تماما بعد كده
اما الشنبر فالدخنة مستمره
إجابة منطقية 100%
دا طقم اصلاح Perkins diesel engine
ملف مرفق 12749
دا طقم اصلاح محرك Ford
ملف مرفق 12750
شكله يفتح النفس في الشغل هههههههه
وبالمناسبة العداد دا بيتباع في محلات معدات السيارات - ودا سهل جدا الميكانيكي يستعمله
وفي بعض السيارات بقدر احصل علي نسب الانضغاط بجهاز الكومبيوتر - الموضوع دا محدش بيعمله خالص - عمري ما شوفت حد بيعمله خالص - علي الرغم ان الموضوع دا موجود في اجهزتهم ويسهل شغل كتير قوي - انا هسال سؤال وعايز الناس تحاول تجاوبة - لتعم المعرفة - وان شاء الله انا هجاوبة بس بعد معرف رايكو
السؤال:- ازاي جهاز الكومبيوتر بيقيس نسب الانضغاط جوا الاسطوانات ، من فيشة كشف الاعطال بدون اي وصلات اضافية؟؟
لست محترفا في الميكانيكا و لكن منتظر الإجابات و المشاركات و أراء المتخصصين برده
للكشف علي الرشاشات فيه اختيار مهم لازم يتعمل
والاختبار دا بنعمله كتير عشان نتاكد من عمل الرشاشات بدون فك نهائي
هل هي دي إجابة السؤال المقصود !!!!!
التعديل الأخير تم بواسطة adham.com ; 19-09-2013 الساعة 05:15 PM
قديم 19-09-2013, 07:23 PM
الموقع: cairo
Preliminary Checks
لا يا استاذ ادهم دا اختبار الرشاشات ملوش علاقة نهائي بالكبس داخل الاسطوانات دا انا حطيطة فقط عشان اللي عايز يختبر الرشاشات مش لازم فك وتركيب - وطبعا الفتاوي الكتير بتاعه بعض الناس يقولك غير رشاشات - طب عرفت منين ياعم الحج- انتوا هتعرفونا شغلنا ولا ايه - وانا كمان بنصح كل الزملاء الافاضل - الميكانيكية بانهم لازم يكون عندهم عداد قياس ضغط - دا ضروري جدا.
اما اجابة السؤال فانا مستني راي الزملاء الافاضل عشان يشاركوا في الحل
التعديل الأخير تم بواسطة romeoalmansour ; 19-09-2013 الساعة 07:50 PM
قديم 22-09-2013, 11:15 AM
الموقع: cairo
اجزاء المحرك
محرك, خراطة, عمره
الساعة الآن 03:49 PM.
