قديم 17-09-2013, 01:35 AM
الصورة الرمزية romeoalmansour
التخصص العملى: Engineer
هواياتي: reading and reading
الموقع: cairo
افتراضي رد: عمرات (اصلاح) محركات السيارات
دا طقم اصلاح Perkins diesel engine
دا طقم اصلاح محرك Ford
الله العظيم أعلي وأعلم
قديم 17-09-2013, 01:41 AM
الموقع: cairo
الطقم لوحده يفتح نفس الميكانيكي انه يشتغل
قديم 17-09-2013, 10:31 AM
الموقع: cairo
Cylinder Head Surface Flatness
Clean the gasket surface of the cylinder head. Check the head for flatness
Machinist’s straight edge and feeler gauge
Diagonal check
Place a machinist’s straight edge across the gasket mating surface. Using feeler gauges, determine the clearance at the center of the machinist’s straight edge and across the cylinder head at several points. Check along the center line and diagonally on the head surface. If the warpage exceeds 0.003 in. (0.076 mm) within a 6.0 in. (15.2 cm) span, or 0.006 in. (0.152 mm) over the total length of the head, the cylinder head must be resurfaced
قديم 17-09-2013, 03:51 PM
الموقع: cairo
Determining Engine Condition
There are a number of methods for evaluating the condition of the engine. A compression test can reveal the condition of the pistons, piston rings, cylinder bores, head gasket(s), valves and valve seats. An oil pressure test can indicate possible engine bearing, or oil pump failures. Excessive oil consumption, evidence of oil in the engine air intake area and/or bluish smoke coming from the tailpipe may indicate worn piston rings, worn valve guides and/or valve seals. In general, it is acceptable for an engine to use one quart of oil every 1000 miles. Engines that use one quart of oil or more in less than 1000 miles should be checked for oil leaks first. Repair any oil leaks before determining how much oil is consumed by the engine, especially if blue smoke is not visible at the tailpipe
Compression Test
A noticeable lack of engine power, excessive oil consumption and/or poor fuel mileage measured over an extended period are all indicators of internal engine wear. Worn piston rings, scored or worn cylinder bores, blown head gaskets, sticking or burnt valves, and worn valve seats are all possible causes. A check of each cylinder’s compression will help locate the problem
  1. Ensure that the engine is filled with oil to the proper level and with the appropriate type (viscosity).
  2. Ensure the battery is fully charged.
  3. Warm-up the engine to normal operating temperature then shut off the engine.
  4. Disable the fuel and ignition systems.
  5. Label and disconnect all of the spark plug wires from the plugs.
  6. Thoroughly clean the cylinder head area around the spark plug ports, and then remove the spark plugs.
  7. Open the throttle plate fully to the wide-open-throttle position.
  8. Block the accelerator linkage open, or have an assistant fully depress the accelerator pedal.
  9. Install a screw-in type compression gauge into the No. 1 spark plug hole until the fitting is snug.
  10. Connect a remote starting switch to the starting circuit.
  11. With the ignition switch in the OFF position, use the remote starting switch to crank the engine through at least five compression strokes (approximately 5 seconds of cranking) and record the highest reading on the gauge.
  12. Repeat the test on each cylinder, cranking the engine approximately the same number of compression strokes and/or time as the first.
  13. Compare the highest readings from each cylinder to that of the others.
    • The indicated compression pressures are considered within specifications if the lowest reading cylinder is within 75 percent of the pressure recorded for the highest reading cylinder. For example, if your highest reading cylinder pressure was 150 psi (1034 kPa), then 75 percent of that would be 113 psi (779 kPa). So the lowest reading cylinder should be no less than 113 psi (779 kPa)
  14. If a cylinder exhibits an unusually low compression reading, pour a tablespoon of clean engine oil into the cylinder through the spark plug hole and repeat the compression test.
    • If the compression rises after adding oil, it means that the cylinder’s piston rings and/or cylinder bore are damaged or worn
    • If the pressure remains low, the valves may not be seating properly (a valve job is needed), or the head gasket may be blown near that cylinder.
Oil and coolant in the combustion chamber, combined with blue or constant white smoke emitted from the tailpipe, are symptoms of a blown head gasket. There may be evidence of water droplets on the engine dipstick and/or oil droplets in the cooling system if a head gasket is blown. The oil will become the consistency of chocolate milk if water is present, and the coolant will appear muddy if oil is present.
Diesel Engines
Checking cylinder compression on diesel engines is basically the same procedure as on gasoline engines except for the following:
  • A special compression gauge adapter suitable for diesel engines must be used because these engines have much greater compression pressures.
  • Remove the injector tubes and remove the injectors from each cylinder.
NOTE: Remove and discard the injector sealing washers.
  • When fitting the compression gauge adapter to the cylinder head, make sure the gauge pressure relief is closed.
  • When reinstalling the injector assemblies, install new washers underneath each injector.
قديم 17-09-2013, 04:04 PM
الموقع: cairo
وبالمناسبة العداد دا بيتباع في محلات معدات السيارات - ودا سهل جدا الميكانيكي يستعمله
وفي بعض السيارات بقدر احصل علي نسب الانضغاط بجهاز الكومبيوتر - الموضوع دا محدش بيعمله خالص - عمري ما شوفت حد بيعمله خالص - علي الرغم ان الموضوع دا موجود في اجهزتهم ويسهل شغل كتير قوي - انا هسال سؤال وعايز الناس تحاول تجاوبة - لتعم المعرفة - وان شاء الله انا هجاوبة بس بعد معرف رايكو
السؤال:- ازاي جهاز الكومبيوتر بيقيس نسب الانضغاط جوا الاسطوانات ، من فيشة كشف الاعطال بدون اي وصلات اضافية؟؟
محرك, خراطة, عمره
الساعة الآن 05:25 PM.
