قديم 27-07-2012, 09:27 PM
افتراضي رد: برجاء مشاهدة المشاركة بالعرض !هدية لمسترهشام الجزار علشان ينفز ويطبق!!!
Here is version 1 of the system.
Needless to say it didn't work.
Being stubborn I didn't give up and buy a Toyota. Instead I built version two.
Distributorless ignition, version 2
After some serious thought I decided it would not be reasonable to use discrete ICs to design the ignition. There were just too many things I was not sure about with regard to the Jaycar ignition. What signals were produced, when, level-triggered vs. edge triggered, it was all a bit foggy. So I decided to use a microcontroller. This would let me fiddle with somftware and not have to design new boards each time.
It's based on an Atmel chip which I had to order from Digikey in the US - they don't seem to sell them in this unfashionable end of the world.
As you can see it's housed in a die-cast box where the old ignition used to be. You can just make out the 20 pin Atmel chip and a D9 connector. Yes, my car has a serial interface...
In order to decide which bank of cylinders should fire I use a cam sensor. This was mounted in front of one of the cam wheels. Tim at Fixations helped with the mounting of the sensor as well as fitting 'timing marks' onto the cam wheel itself. The timing for these does not have to be exact as I only need to know what 'quadrant' I need to be in. The sensor is just visible in the photo below (right hand cam wheel).
The two coils I used are from a model of Holden which is pretty common in this part of the world. As it turned out, the low voltage connectors on the coil are very close to, but entirely different to any sort of commonly available connector. It's a female connector so there's no easy way to fudge something. I went to Holden to enquire about the mating part, but of course it costs $600. It turns out it's more than a connector; it includes electronics too. Gee wizz, that's just great. Staring at the coil for a while I decided to fabricate a connector. Hanna helped, and cutting and filing at small pieces of brass for some time we had some really nice mating connectors.
All hardware installed I set about writing the software. Some experimentation was required in order to get the system running. It's amazing how many parameters there are for such a simple system. Also, it's amazing how loud it can be when an air/fuel mixture explodes at the wrong time (say in your exhaust) when you are testing in the garage. After much spluttering, coughing, head-scratching and thought I finally reverse-engineered the Jaycar system enough to figure out what I needed. A few versions of code later (presently the car runs MartinOS V1.03) it burst into life. Yippee!
It ran pretty well for the next few months. A nice professional PCB is in the works to replace the hand-made in the garage at home one I have been using.
Then bad things happened
Where is all the water going?
After changing to the distributor-less system the car was pretty reliable. The only thing I noticed in the following months was that it would consume spark plugs a little more regularly than it used to. Number four always appeared a little discoloured. See the photos below; left is a plug from number one. Right is a plug from number four.
I had changed a stage hotter in plugs in an appempt to prevent this fouling. It kind of worked, but not very well. The car kept consuming plugs. The plugs above are NGK BP5ES from memory.
For what it's worth, many people with older cars have problems with the current fuel in New Zealand. It causes fouling quite badly so it is quite common to run slightly hotter plugs than in a country where decent fuel is available.
After some time without any body repairs that dreaded rust started to appear. So I took the car in for work. I'm amazed how a new car gets repaired in a day or two, but as soon as the car is old, the panel-beater gives it lower priority. Anyway, after being passed over for a few weeks, the car is finally ready. So I'm driving home and the temperature rises above where it usually sits. I stop and check the water level in the radiator. Oh no, there is no water... This reminds me of another story (there are so many) about a colleague of mine who had his car worked on. When he picked up the car he noticed that the temperature went up higher than normal. He stopped to have a look under the hood and noticed the radiator was missing. Yes, the garage had removed it and not replaced it. Good 'ol NZ eh.
My car still had its radiator, just no water. So had the water been drained or had it disappeared by another means? Well, in the days that followed I kept a close eye on the water level. It appeared to be disappearing. Oh no, head gasket? The oil looked fine though.
Of course this happens when your mechanic takes a three month leave to go to Europe. So it's off to another mechanic, in fact the guys who service my 911. As it turns out they pressurise the system and water blasts out number four spark plug hole. Oh dear.
They remove the head and find a leak between the water jacket and the inlet of number four. Number four. That explains it. Looking at the rather clean valve on number four it's possible to see I've been running with water injection (unintended in this case).
Since the leak is in a low-pressure section I decide to have it welded up. The head will then be skimmed to make sure it's flat again. All the Abarth gasket bits (130TC) and new bolts are ready. Just have to wait on the engineering shop now.
I took some photos of the car without its head. It really does look poorly.
While the head is off awaiting work I decide to have hardened valve seats installed. There is a bit of a story behind this. A few years ago the government stopped the sale of leaded petrol in New Zealand. This of course was a bad thing for classic cars that rely on the lead for lubrication. As a band-aid, most garages started selling a fuel additive called Valvemaster. This is added to the fuel tank each time you fill up. It's a hassle of course to do this. The price of Valvemaster has also been rising steadily. I've paid NZ$2 (about 1 Euro) per Valvemaster at some garages. One shot does 20L of fuel. The alternative is to replace the exhaust valve seats with hardened versions that mean the car can run on unleaded fuel without any additive. Less hassle that's for sure. Since the head is off the car it makes sense to do it now.
Here is a photo of the carbs as they lie on the bench at Autothority.
We're about to start week five since the car was taken in. I'm trying to remember what it was like to drive. I think first gear is left and forward...?
وعلشان استاز ايمن واستاز محمد صلاح القاضى !!
رابط مهم جدا
http://www.google.com.eg/url?sa=t&rct=j&q=131%20ab arth%20volumetrico&source =video&cd=7&ved=0CEoQtwIw Bg&url=http%3A%2F%2Fplay. kendincos.com%2F174578%2F Wpttxdhrvnrjntxjn-motor-131-abarth-16v-gr4.html&ei=HI7pT-XwNIHWsgbd4p3GDg&usg=AFQj CNGVfI2-l05x4bEnLOP2gKkb029Bjg
موتور مين ده ؟؟؟؟؟؟!!
:GR OWIN~12::GROWI N~12::CONGRA~2 38::CONGRA~23 8:
أحمد عثمان محمد
قديم 29-07-2012, 01:45 PM
الصورة الرمزية أيمن الروبي
أيمن الروبي أيمن الروبي غير متواجد حالياً
التخصص العملى: تجديد السيارات
الموقع: الجيزة
أيمن الروبي has a reputation beyond reputeأيمن الروبي has a reputation beyond reputeأيمن الروبي has a reputation beyond reputeأيمن الروبي has a reputation beyond reputeأيمن الروبي has a reputation beyond reputeأيمن الروبي has a reputation beyond reputeأيمن الروبي has a reputation beyond reputeأيمن الروبي has a reputation beyond reputeأيمن الروبي has a reputation beyond reputeأيمن الروبي has a reputation beyond reputeأيمن الروبي has a reputation beyond repute
Smile رد: رابطة ملاك ومحبى السفينه فيات 132
كان يا ما كان كان في منتدي اسمه مصر موتورز كان علي رابطه ولا كل الروابط رابطه اسمها محبي السفينه 132
وكان فيها اعضاء عمالقه زي
اتش كارز ادماير القاضي مصطفي عاطف احمد صادق
اوم ايه دخل عليهم رمضان 2012 فجأة اختفو مش عارف راحو فين
صايمين بيصلو بيقرو قرآن الله اعلم
انتو فين يا رابطه انتو فين
استفسر عن دهان سيارتك !!!
اللهم لك الحمد كما ينبغي لجلال وجهك وعظيم سلطانك
ورشة إيه آي أوتو بينت لسمكرة ودهان السيارات
قديم 29-07-2012, 02:05 PM
الموقع: طنـ بلد الاونطه ـــطا
افتراضي رد: رابطة ملاك ومحبى السفينه فيات 132
انا موجود
بس انتم اللى فين
: shyy:
: Wkiss5:
دا لينك اولتراس فيات 132
دا لينك صفحتى على الفيس بوك
قديم 29-07-2012, 02:20 PM
الموقع: الجيزة
عامل ايه يا قاضي
وايه اخبار العربيه بتاعتك لسه راكنها حرام عليك
معتقدش انها تستاهل منك كده
قديم 29-07-2012, 02:22 PM
من انا؟: الفقير إلى الله
وأنا كمان موجود بس يادوب الوقت على أد الشغل مش بعرف افتح صفحة نت
انا بوصل الشغل الساعة 8 وبنزل اروح الساعة 2
ومعنديش نت فى اى حته بروحها
عربيتى لسه ماخلصتش واليومين دول ونة الكارونة زادت حبتين
خلاص العربية باظت من مجاميعوا والحمدلله على كل حال
انا نفسى اتسدت تماما عن العربيات لدرجة انى ركنتها ومش هركبها تانى
كل سنة ونتوا طيبين وأتمنى أشوفكم قريب بإذن الله
132, fiat
الساعة الآن 10:32 AM.
