قديم 22-07-2012, 09:07 PM
حصرى رد: شكر خاص لمستر هشام الجزار !! للبيع سيات 133 2000 سى سى !
كلاتش سيرفو بجوار الفتيس !!!
!solenoid!
http://community.webshots.com/user/vw68autobug
فيات 124 و131 كمحرك خلفى !!
124 كدفع امامى او خلفى لاكن لازم يتركب بالعرض !الفتيس يؤكد زلك !يا ترى فيات ركبته
على عربية ايه ؟؟؟؟!!
be lucky enough to find a good VW gearbox and a man to makes up the adaptors and flywheels to fit between the Fiat engine block to VW gearbox
Seat/ Fiat 133
Factory date: 01/2011
Price: Offer!!!
Details: Just made from new parts!! fiat 2.0 TC engine with Weber carburators. Programmable ignition system, ignition timing after every 500 rpm, launch control, shift light, rev limiter. Hydraulic handbrake. New fuel and brake lines. New electric cables etc Polycarbonate windows but not windshield (it is glass). VW beetle´s fully made short ration gearbox with bog 2-gear. Don´t hesitate to ask more!!
Contact Name: Ville-Pekka Vaara
Contact Phone: +358 44 553 82 59
As mentioned elsewhere, close ratio 3rd and 4th gears are available for the standard Fiat 850 4 speed gearbox as is a small number of 9/35 ring and pinions (3.888 to 1)(without limited slip diff) for the same standard gearbox , both more suitable for the higher power motors.
Fiat 128 cardans on the outer end and made the side plates with VW type 1 gearbox joints for the inner side. Works great, but a lot of work.
So the man designed a new system. It incorporates the following items:
2 gearbox side flange kits with a bearing and seal (no rubber boots required)
2 gearbox stubaxles set up to use standard "square stones". Use yours as Fiat made two different sizes.
2 Tripode housings with tripode and rubber boot 70mm diameter. - these bolt directly to the side flange kit and are replaceable.
2 axles splined both ends
2 tripode housings with tripode and rubber boot 70mm diameter - wheel hub end - fits inside Fiat 600 trailing arms without modifications
2 stub axles
2 bearing carriers
2 wheel bearings
2 wheel hubs (you could use Fiat 128 wheel hubs if you wanted.
There you have it, a complete system with all parts individually replaceable.
this man have the prototype done and with the manufacturer at this point. he just waiting to get the first shipment in. he have not been able to set a price as this time.
DR/elmanahry, Hisham.Elgazzar, حازم شاهين
:0101 04~171:
قديم 23-07-2012, 12:20 AM
حصرى رد: seat 133 tuning
nktis
:lov eu::0 10104~171صورة)
قديم 30-07-2012, 01:27 AM
مميز 1300. Based on the familiar Fiat 850 Coupe, but with a 1300 cc Fiat 124 motor
هنا بقى السيات ال133 بموتور فيات 124
و1300 سى سى والردياتير قدام بمروحة تبريد
128
ومواسير المياه ماشية من تحت العربية زى الشكمان او فى فردة الشاسيه زى ما تحب !!
133T
شايف ماسورتين المياه جايين من الردياتير يمين
وماشين فى فردة الشاسيه شمال بطول العربية
لان فى بعض الموديلات كان ده غطاء قربة والردياتير قدام وموديلات تانية كان الردياتير فى الكارتيرة الخلفية !!
السيات ال 133 عليها موتور الفيات 131 1300 سى سى الكامة الواحدة !! بتاع الشاهين 1300 يعنى !!
بس الردياتير راكب فوق العجلة على الكارتير اليمين
الخلفى !وفى موديلات فتحوا شبكة قدام ووصلوا خراطيم بطول العربية وحطوا الردياتير قدام مروحة كهرباء برضه!
زى ما انت شايف غطاء المياه ومفتوح له فتحات تهوية وليه مروحة كهرباء زى ال 128 !!!
الردياتير قدام !!
وطبعا رجعوا البطارية
فى الخلف مكان الردياتير
بس ممكن تسيب البطارية قدام
زى ما هيه !!!!
fiat_dino_2400_coupe
:CH UBBY~36::CHUBB Y~36:سو قسوق
Fiat Abarth OTR 1000
The last Abarth brought into the US by Abarth Sales Corp was an OT 1300. Based on the familiar Fiat 850 Coupe, but with a 1300 cc Fiat 124 motor.
Fiat 500X Crossover Sneak Peek
Fiat 500X
Fiat 500L
قديم 30-07-2012, 04:57 AM
الهولندى الطائر الهولندى الطائر غير متواجد حالياً
الهولندى الطائر has a reputation beyond reputeالهولندى الطائر has a reputation beyond reputeالهولندى الطائر has a reputation beyond reputeالهولندى الطائر has a reputation beyond reputeالهولندى الطائر has a reputation beyond reputeالهولندى الطائر has a reputation beyond reputeالهولندى الطائر has a reputation beyond reputeالهولندى الطائر has a reputation beyond reputeالهولندى الطائر has a reputation beyond reputeالهولندى الطائر has a reputation beyond reputeالهولندى الطائر has a reputation beyond repute
افتراضي رد: seat 133 tuning
كارز ادماير
مدرسة
والمشكلة
من كثر المعلومات اللى بيقولها
بتوه ...
ومش عارف اركز
مش ملاحق
ده مكنة معلومات بتطبع ورق
بس نرجع ونقول
أستاذ ورئيس قسم وكبير قوى
ولو الامر بأيدى
أبعتك بعثة فى المانيا وواحدة فى امريكا علشان تلقط الجديد وترجع تعمل مصنع كبير لعربية نقول عليها عربية صح
مصر عظيمة بشبابها فعلا زى كارز ادماير
الله عليك
ربنا يباركلك
ورمضان كريم عليك وعلى الجميع الحاضرين هنا
بسم الله الرحمن الرحيم
{يُرِيدُونَ أَن يُطْفِؤُواْ نُورَ اللّهِ بِأَفْوَاهِهِمْ وَيَأْبَى اللّهُ إِلاَّ أَن
يُتِمَّ نُورَهُ وَلَوْ كَرِهَ الْكَافِرُونَ }التوبة32
صدق الله العظيم
قديم 30-07-2012, 05:09 AM
الصورة الرمزية أحمد عثمان محمد
أحمد عثمان محمد أحمد عثمان محمد غير متواجد حالياً
من انا؟: بكالوريوس المعهد العالى لعلوم الكمبيوتر و تكنولوجيا الإدارة بسوهاج و معادل ببكالوريوس تجارة
التخصص العملى: مجال الكمبيوتر
هواياتي: السيارات ، الكمبيوتر
الموقع: جمهوربة مصر العربية - محافظة أسيوط - مركز أبنوب
أحمد عثمان محمد has a brilliant futureأحمد عثمان محمد has a brilliant futureأحمد عثمان محمد has a brilliant futureأحمد عثمان محمد has a brilliant futureأحمد عثمان محمد has a brilliant futureأحمد عثمان محمد has a brilliant futureأحمد عثمان محمد has a brilliant futureأحمد عثمان محمد has a brilliant futureأحمد عثمان محمد has a brilliant futureأحمد عثمان محمد has a brilliant futureأحمد عثمان محمد has a brilliant future
الهولندى الطائر
cars admire, كارز ادماير
الساعة الآن 03:19 PM.
