موضوع مغلق
قديم 27-09-2011, 02:52 AM
الصورة الرمزية titos
titos titos غير متواجد حالياً
التخصص العملى: Build Refrigeration Storge Systems at Assarprofessional
هواياتي: any thing about (cars-computer-tech )
الموقع: damnhour
titos is a jewel in the roughtitos is a jewel in the roughtitos is a jewel in the roughtitos is a jewel in the rough
افتراضي رد: زيت المحركات المانى الصنع LIQUI MOLY
استاذه ريهام
شكرا على سرعه الرد و الاهتمام
  #77
قديم 27-09-2011, 03:00 AM
افتراضي رد: LIQUI MOLY
elmanahry
Seals punctured tyres and pumps them up again. Used for all types of tyre with and without inner tube.
متى سيتوفر هذا المنتج فى مصر ؟!!
  #78
قديم 27-09-2011, 03:02 AM
افتراضي رد: the car care portfolio
car wax
Liqui Moly Hard Wax - 600ml
polish, wax, cleaning agents, wheel rim cleaner and leather care.
“With our motor oils and additives we already keep the engine’s interior clean and neat. Now we take care of the car’s exterior”, said Salvatore Coniglio, the export area manager at LIQUI MOLY responsible for UAE. New products were added to the car care portfolio, existing formulations were improved to get even better results, packaging was redesigned to give a better look and package size modified. Altogether there are more than two dozen relaunched or newly introduced products
Liqui-Moly Gloss Spray Wax - 400ml
liqui moly V-BELT SPRAY 400ml
V-BELT SPRAY 400ml
Eliminates V-belt slip and squeals. Keeps them supple and increases their service life. Protects belts and pulleys from wear. Increases efficiency and tractive force. Cares for and protects V-belts. Operational area: For all types of V-belts such as leather, rubber, balata, etc. Not suitable for flat belts.
Liqui-Moly Fabric Protector - 400ml
For optimum protection against the wet. Fabrics remain pliable and breathable. Protects against oil and grease spots and dirt.
Operational area: Universal use for fabric convertible tops, rucksacks, awnings, tents, sports clothing and parasols. Also suitable for products with climatic membranes and suede. They stay pliable and breathable. Protects against spotting.
Liqui-Moly Cockpit Shine - 200ml
Makes dull and weathered plastics look new again. Plastic components regain their original appearance and do not dry out. Stops wearisome rattles and squeaks. Treatment is without greases, is antistatic and dust repellent. Good lubricating effect on rubber and plastic components, impregnates and insulates -- universal application.
Operational area: For rattling and squeaking fascias and sticking safety belts (spray belt on both sides). For all matt plastics such as plastic bumpers and spoiler etc. For general interior care in vehicles.
Liqui-Moly Car Wash Sponge
Specially absorbent and gentle on paint. Long-life and wear resistant.
Operational area: For glass, paint and plastic.
لتنظيف المحرك من الخارج بشكل جاف !!
Liqui-Moly Engine Compartment Cleaner - 400ml
Makes engine compartments brilliantly clean. Dissolves oil and greasy contaminants, tar and brake dust. With high washing and cleaning efficiency. After leaving for a short time to take effect, stubborn residues are easily removed. Does not contain chlorinated hydrocarbons.
Liqui-Moly Lead Subsitute - 250ml
مزيل الرصاص من الوقود بشكل نهائى حتى لا تتضرر الصمامات وقواعدها مما يؤدى لضعف
عام فى تاءدية المحرك !!
High valve seat abrasion. Noticable loss of compression, i.e.: less performance or even engine failure.
Lead substitutes enables an unleaded passenger car handling. Lubricates and protects non-hardened valve seats. Minimizing abrasion, it prevents the engine of damage. For optimum compression.
Liqui Moly Carburetor and Valve Cleaner
منظف كاربراتير وصبابات فى وقت واحد !!
Did my valve cover gaskets and cam chain tensioner gaskets along with spark plugs.
Have been using Lubro Moly 5W40 for as long as i owned the car and everything looked so clean.
Click here to view the original image of 800x533px and 122KB.
Click here to view the original image of 800x533px and 73KB.
يمنع المسامير من الفك من تلقاء نفسها!!!
Bolt lock fluid Liqui Moly high-strength 50g, removable
مانع تسريب زيت المحرك داخليا او خارجيا ومانع تعريق البوجيهات !ديزل وبنزين!
Lubro-Moly Motor Oil Saver (300 ML)
Lubro-Moly Motor Oil Saver (300 ML) Review
Lubro-Moly Motor Oil Saver (300 ML) Feature
  • Reduces oil consumption via the piston rings and valve guides
  • Prevents blue, smoky exhaust fumes
  • Prevents leaks due to leaks at elastomeric seals
  • Regenerates engine seals made of plastic and rubber
  • Prevents pollution of the environment due to oil dripping from the engine
Lubro-Moly Motor Oil Saver (300 ML) Overview
Suitable for all petrol and Diesel engines and compatible with all commercially available engine oils. 300 ml is sufficient for 3 -- 4 litres of engine oil. Sealing first takes effect after about 600 -- 800 km.
مضاعف فاعلية البنزين Liqui Moly Speed Tec Petrol Speed
LEAK FINDER
يكشف مكان التسريب لاى سائل بالسيارة !!
is a leak testing fluid for locating leaks in gas and compressed-air systems. Leak-Finder Spray is used to find leaks in tanks, pipework, hoses, screwed connections, welded seams, flange connections and fittings. Water-soluble, biodegradable test fluid filled with environ-mentally-compatible propellant. The product’s high foam yield ensures economic and reliable use.
للحام اى كسر فى المحرك او الفتيس على البارد
Knet-Metall 50g
is a 2-component epoxy putty which bonds to all materials. Stable in the presence of salt solutions, dilute aqueous acids and dilute alkalis. Can be ground, sawn and painted over after 3 hours.
كاشف التنفيس فى المانيفولد !!
INTAKE SYSTEM LEAK DETECTOR 200ml
Intake System Leak Detector is extremely easy to use and locates leaks in the intake system within seconds. As soon as the engine speed has dropped, the leak has been located. The product has a high auto-ignition temperature and complies with the safety regu-lations. Compatible with engines and catalytic converters.
مهما كانت لزوجة الزيت مرتفعة فى الفتيس المانيوال او فى الكرونة هذا المنتج يسمح بتسييلها ولاكن دون المساس باللزوجة المطلوبة مما يوفر فى استهلاك الوقود !!
HYPOID GEAR OIL TDL SAE 75 W-90
Multipurpose gear oil for universal use. As this is a total drive line (TDL) gear oil, it is most suitable for lubricating all drive elements, from demanding synchronised and non-synchronised manual transmissions to hypoid drive axles. Reduced friction as a result of the optimum viscosity level helps to save fuel.
Di-Electric Grease
هو عبارة عن سيلكون+شحم ممزوجين سويا بشكل خاص لعدم صداء كابلات البوجيهات والبطارية ومنع تهريب الكهرباء واحكام الشرارة للبوجيهات !!
Max Professional Di-Electric Grease protects, seals, lubricates and insulates electrical contacts, spark plugs and battery terminals.
Di-Electric Grease
Use on spark plug wires, trailer hitch
After putting the new spark plugs in, put a liberal amount of
Electric Grease
هنا محطوط على راس البوجيه !!!
هنا محطوط على كابل البوجيه نفسه !!!
Also prevents spark plugs from fusing to boots. Required for modern cars
ده منتج غير ليكى موللى لانى مالقيتش صورته !!!
Generally, dielectric grease is used in any situation
متى ستتوفر تلك المنتجات فى مصر ؟!!
  #79
قديم 27-09-2011, 03:06 AM
افتراضي رد: Removing Insistent Carbon Deposits
Liqui Moly Engine Flush - 500ml
very important link to see it
http://www.liqui-moly.de/liquimoly/mediendb.nsf/gfx/7E856D319BD165B5C12573B00 0545978/$file/TI%20removing%20carbon%20 deposits.pdf
Dislodges sludge and lacquers to improve compression and reduce exhaust emissions. Great for chain tensioner systems and camshaft/valvetrain components. PLEASE NOTE: This item must be shipped via ground carrier, so it is available only in the 48 contiguous United States and Canada
Even though this engine has moderate miles on it, the lack of use and the short drive periods have likely built up a fair amount of internal oil varnish and sludge, additionally, the piston rings may be a bit loaded with varnish and carbon. This would all be due to the lack of longer running periods at full engine operating temperature.
We would recommend an application of the Lubro-Moly Engine Flush. This product is added to the hot oil and then the engine is idled for about 15 minutes. You then drain and change the oil as usual. The Engine Flush works on dissolving the varnishes and oil sludge on the internal engine surfaces as well as the varnish and carbon in the piston ring grooves on the pistons. You may find that a couple applications may be required to both clean up the internals and to free up the piston rings
Valve Clean (150 ML) Feature
  • Better engine performance
  • Lower fuel consumption
  • Lower pollutant emissions
  • Protection against corrosion and carburetor icing
  • Stops pinging, knocking, hesitation and dieseling
Engines are subjected to extreme loads even under normal driving conditions such as town and commuter traffic, short journeys and traffic jams. This sort of use causes the build-up of deposits on valves, in the combustion chamber and in the carburetor. Valve Clean cleans valves, injection systems, intakes, carburetors and combustion chambers and keeps them clean. Clean engines save fuel. Promotes optimum engine performance and fuel utilization. The combustion produces a lower level of pollutants and the engine is spared. Protects against corrosion and carburetor icing. Tried and tested in turbo-chargers and catalytic converters.
Sealing remover Liqui Moly 300ml
Glued and burned-in sealings are removed in little time with little effort. Just spray and remove. Quick and easy removal of burned and hardened sealings and glues on engines and machine parts. Also adheres to vertical areas.
liqui moly fuel system cleaner
Pro-Line JetClean Fuel System Cleaner
removes carbon and other deposits from fuel distributors and injector valves
- effective in all injection systems
- leads to precise injector dosage and atomisation of fuel
- secures the optimum drivablility and low fuel consumption
- optimises exhaust gas emissions
- increases operational reliability and economy
Liqui Moly Jectron Fuel Injector Cleaner
Jectron every 1250 miles
1mile=1.6km
For precise, consistent fuel injector spray, use Jectron every 1250 miles. Eliminates starting problems, rough idling and poor throttle response caused by carbon and other deposits in the injectors, valves and throttle body. Safe for catalytic converters and all injection systems. 300ml bottle with fill nozzle.
Liqui Moly DieseL Purge
Liqui Moly Diesel Purge
Diesel Purge removes deposits from injectors and the pistons/combustion chamber. Eliminates engine-running problems. No more knocking under partial load -- smoother idling and softer engine running. Cleaner injectors produce optimum engine running. Cleans the whole fuel system. Protects against corrosion. Guarantees good combustion, increased economy and operational reliability.
Liqui Moly diesel purge is the only concentrated product that can be used while the injectors are still in the car! When used about every six months, this maintenance routine will keep your injectors at their optimum performance. Diesel purge is easy to use. Just pour into your tank or follow the simple instructions on the bottle. Diesel Purge removes deposits from injectors and the pistons/combustion chamber. Liqui Moly Diesel Purge is a very popular product with owners of diesel European cars, SUVs and trucks. Its reputation is outstanding!
Liqui Moly Diesel Purge Features:
  • cleans fuel systems
  • breaks down deposits in injectors
  • improves the ignition performance (cetane number) of diesel fuel
  • prevents partial-load knocking
  • protects against corrosion
  • guarantees optimum combustion
  • increases operational reliability and economy
Liqui Moly Diesel Purge comes in a 500ml (17.0 ozs.) can. You can add the whole can to your fuel tank. In particularly tough cases, you may add a second can if needed.
منظف بوابة الانجكشن !!
The all-round supplier of auto chemicals from Ulm in Germany has developed a service product which is particularly suitable for cleaning throttle valves. This active solvent dissolves and removes the deposits and contamination such as oil, resin and adhesives which are typically found in the intake system. With the special formulation and, above all, 60 cm long spray extension in the form of a thin, flexible tube, impurities can be removed from inner components just as they can from the injectors.
This cleaner guarantees the proper operation of all moving parts, reducing e.g. fuel consumption.
Throttle valve cleaner is available in a 400 ml can.
منظف الكربراتير !!
Liqui-Moly Carb Cleaner -MTX
Cleans contaminants from the housing, throttle valve, jets, and bores etc. Simple to use. Cleaning without dismantling. Operational area: Used for degreasing and cleaning the inside and outside of carburettors
منظف الكربراتير تفك فلتر الهواء والموتور لايعمل وتبداء البخ داخل جسم الكربراتير وخارجه وفى جميع الفتحات داخليا وخارجيا !! spray Liqui Moly Carb Cleaner.
DESCRIPTION
Carburettor Housing Cleaner is a special mixture of solvents for fast and thorough
removal of grease-type contaminants and deposits on carburettors and injection
systems such as housings, throttle valves, injectors and bores.
PROPERTIES
- rapid and effective cleaning and degreasing
- cleaning without dismantling
- simple to use and economical
APPLICATIONS
Used for degreasing and cleaning the inside and outside of carburettors and fuel
injection systems.
APPLICATION
Spray all components which are exposed with the air filter removed and with the
engine switched off. Spray external components and allow to dry. Repeat cleaning
in extreme cases. Start the engine and allow to run at a moderate speed. Do not
spray painted components.
For parts which have been repainted, check paint for compatibility and colour
changes by testing on a hidden area.
AVAILABLE
Carburettor Housing Cleaner 400 ml aerosol
SPRAY
:GR OWIN~12::GROWI N~12:
[/SIZE]
  #80
قديم 27-09-2011, 04:26 AM
esso3030 esso3030 غير متواجد حالياً
esso3030 is on a distinguished road
لو سمحت انا عرفت من المشاركات ان الشركة لديها موزع فى الزقازيق ارجو معرفة مكانة ورقم تليفونة حيث اننى اسكن فى الزقازيق
موضوع مغلق
ليكوى مولى, liqui moly, زيت, زيت محرك, زيت الموتور, زيت فتيس, زيوت السيارات, زيوت زادو, زيوت سيارات, revitalizant, xado
الساعة الآن 03:16 AM.
