سوزوكىXL7-قوة وأداء مدهش
القوة00 الفخامة 00الاداء المدهش00
هو عنوان سيارة سوزوكى الxl7 الموتور الاكبر من سوزوكى العالمية V6-3.6liter أداء جبار وقوة تفوق الاحلام =250حصان كفاءة ونعومة فى الاداء <TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TH>M odel name</TH><TD class=unit> </TD><TD>XL7</TD></TR><TR><TH>Body Type</TH><TD class=unit> </TD><TD>SUV</TD></TR><TR><TH rowSpan=2>Engine</TH><TD class=unit rowSpan=2> </TD><TD>Petrol</TD></TR><TR><TD>3.6L V6 VVT</TD></TR><TR><TH>Drive system</TH><TD class=unit> </TD><TD>2WD/4WD</TD></TR><TR><TH>Number of doors</TH><TD class=unit> </TD><TD>5</TD></TR><TR><TH class=functionTitle colSpan=3>DIMENSIONS</TH></TR><TR><TH>Overall length</TH><TD class=unit>mm</TD><TD>5,008</TD></TR><TR><TH>Overall width</TH><TD class=unit>mm</TD><TD>1,836</TD></TR><TR><TH>Overall height</TH><TD class=unit>mm</TD><TD>1,726</TD></TR><TR><TH>Wheelbase</TH><TD class=unit>mm</TD><TD>2,857</TD></TR><TR><TH>Tread Front/Rear</TH><TD class=unit>mm</TD><TD>1,565/1,570</TD></TR><TR><TH>Minimum turning radius</TH><TD class=unit>m</TD><TD>6.4</TD></TR><TR><TH>Minimum ground clearance</TH><TD class=unit>mm</TD><TD>200.6</TD></TR><TR><TH class=functionTitle colSpan=3>CAPACITIES</TH></TR><TR><TH>Seating capacity</TH><TD class=unit>persons</TD><TD>5/7</TD></TR><TR><TH>Fuel tank capacity</TH><TD class=unit>litres</TD><TD>70.4</TD></TR><TR><TH class=functionTitle colSpan=3>ENGINE </TH></TR><TR><TH>Type</TH><TD class=unit> </TD><TD>N36A VVT(3,564)</TD></TR><TR><TH>Valve arrangement</TH><TD class=unit> </TD><TD>DOHC-24V</TD></TR><TR><TH>Maximum output</TH><TD class=unit>kW/rpm</TD><TD>188/6,400</TD></TR><TR><TH>Maximum torque</TH><TD class=unit>N・m/rpm</TD><TD>330/2,300</TD></TR><TR><TH>Fuel distribution</TH><TD class=unit> </TD><TD>Multipoint injection</TD></TR><TR><TH class=functionTitle colSpan=3>TRANSMISSION</TH></TR><TR><TH>type</TH><TD class=unit> </TD><TD>6AT with manual mode</TD></TR><TR><TH class=functionTitle colSpan=3>CHASSIS </TH></TR><TR><TH>Brakes(Front)</TH><TD class=unit> </TD><TD>Ventilated disc</TD></TR><TR><TH>Brakes(Rear)</TH><TD class=unit> </TD><TD>Ventilated disc</TD></TR><TR><TH>Suspension(Fro nt)</TH><TD class=unit> </TD><TD>MacPherson Strut & coil spring</TD></TR><TR><TH>Suspension(Rea r)</TH><TD class=unit> </TD><TD>Multi-link </TD></TR><TR><TH>Tyres</TH><TD class=unit> </TD><TD>235/60R17</TD></TR><TR><TH class=functionTitle colSpan=3>WEIGHT </TH></TR><TR><TH>Kerb weight M/T (min.)/(with full options)</TH><TD class=unit>kg</TD><TD>-</TD></TR><TR><TH>Kerb weight A/T (min.)/(with full options)</TH><TD class=unit>kg</TD><TD>1,777/1,935</TD></TR><TR><TH>Gross vehicle weight</TH><TD class=unit>kg</TD><TD>2,475 </TD></TR></TBODY></TABLE> ---------------------------------------------------------------------- |
رد: سوزوكىXL7-قوة وأداء مدهش
تصميم داخلى مريح وشكل خارجى مش مريح خالص تسلم ايدك يا دكتور |
فعلا شكلها من بره غير عاطفي من بره خصوصا الفوانيس اللي حاسس انها قص و لزق دي
حـازم خـضـر
أدوات الموضوع | |
