Hydrogen Fuel Generator - How to Turn Water Into Gas
It's Time to Turn Water Into Gas And Save Money While Gaining Mileage
It applies to cars, boats, motorcycles or even trucks. No more stress again with rising fuel price when you can turn water into gas. Yes, I mean water. Since hundreds years ago, people have been utilized water to generate energy. Today, we adapt that technology to
create powerful homemade hybrid cars. The name is
this is just awesome device that must be plugged in to your car.
This reminds me to the concept of turbo-charger for diesel engine
where air pumped into the engine to produce perfect combustion. By changing nozzle size, fuel injection can be adjusted so that the efficiency burning also can be obtained. And the outputs are more horsepower with better mileage and lower emission.
Because you get better mileage, this technology absolutely helps you
save more and more money.
There are various type of hybrid vehicles. Take one for example, hybrid diesel from
Mitsubishi combine both electric and diesel engine that work simultaneous in certain speed. There's an automatic on-off switch allows the vehicle pick when the electric will be turn on and when it will be
switch to diesel. This concept also used by other type of hybrid cars. Using
hydrogen fuel cell to produce HHO gas that will be injected to air intake system to obtain efficiency burning fuel.
Take a look at the example above.
Hydrogen Fuel Generator can be placed beside engine.
This will not harm your car, so you don't need to worry. Just make sure you have enough understanding about how and
where to put the device. When it completely plugged, you can begin to record the mileage and the amount of fuel you should buy every week.
Better of all, you won't need an adviser to build your own
homemade hydrogen generator for cars. This is just simple
Do-It-Yourself (
DIY) project which is so cheap and easy to do. This is just like stringing toys so everybody can do that exactly at home. If you're eager to start, you can use proven
hydrogen generator plans that already tested by the expert.
Or try this
Simple Fuel Generator System by clicking
here.
Other opportunity using
Hydrogen Fuel Generator is making money in the business. We know that hybrid cars are so expensive. If you have skills in this field then it is not impossible the business begin coming to you, right after you demonstrate your first hybrid.
In other hand, using
hydrogen generator can save our environment from rising pollution. As we know that north pole almost melted down because global warming effect increasingly out of control. We do not need to wait for all factories to produce hybrid for all variants, or wait until the world oil reserve is completely exhausted. The best thing to do now is
Go Green -
Turn water into gas and start building better environment.
![W6w200504111340266d8924c1a[1]](images/smilies/w6w200504111340266d8924c1a[1].gif)
:w6w2 00504111340266d
