قديم 01-06-2009, 01:48 AM
الصورة الرمزية د0تامر محمد
د0تامر محمد د0تامر محمد غير متواجد حالياً
من انا؟: طبيب بشرى -كاتب قصة وروائى
التخصص العملى: طبيب بشرى
هواياتي: الكتابه خاصه الادبيه -السيارات
الموقع: الشرقيه
د0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond repute
افتراضي رد: أحدث سيارات شيرى الصينية
*شيرى qq
المواصفات
Engine0.8L1.1L
Transmission5MT5AMT5MT
DriveFF
Engine
Engine code zSQR372SQR472F
Number of cylinders4 in line
Valve mechanism12 valves DOHC16 valves DOHC
Fuel injection systemElectronic Multipoint Injection
Displacement (cc)8121083
Bore×stroke (mm)72×66.5
Compression ratio9.5:1
Maximum power (Kw/rpm)38/600050/6000
Maximum torque (Nm/rpm)70/3500~400090/3500~4000
Fuel tank capacity (L)38
Fuel consumption at 90KM/h(Litres/100km)6565.2
Maximum speed (km/h)130
Fuel typeUnleaded Gasoline
Dimensions & Weight
Length×Width×Height (mm)3550×1495×1485/1530(choose rack)
Wheelbase (mm)2340
Front tread (mm)1295
Rear tread (mm)1260
Minimum ground clearance(full loading) (mm)125115
Turning radius(minimum) (m)5
Kerb weight (kg)880900890
Tyre Size155/65R13 73H
Suspension & Brake
Front suspensionIndependent Macpherson strut with cylindrical coil spring, single transverse link and dual-acting damper
Rear suspensionNonindependent trailing arm type with cylindrical coil spring and dual-acting tube damper
Front BrakeDisc(venti)
Rear BrakeDrum
ABS+EBDOptional
اسبيرانزا=a5
مواصفات
Engine2.0L1.6L1.8L
Transmission4AT5MT
DriveFF
Engine
Engine code zQR484FSQR481FSQR481FC
Valve mechanism16 valves DOHC
Displacement (cc)197115971845
Bore×stroke (mm)83.5×9081×77.581×89.5
Compression ratio10:0110.5:1
Maximum power (Kw/rpm)995/550195/575080/600097/5750
Maximum torque (Nm/rpm)180/4001180/4300~4500144/4300~4500130/4300~4500
Fuel tank capacity (L)52
Fuel consumption at 90KM/h(Litres/100km)7.26.86.66.8
Maximum speed (km/h)185180185
Dimensions & Weight
Length×Width×Height (mm)4552×1750×1483
Wheelbase (mm)2600
Front tread (mm)1505
Rear tread (mm)1505
Minimum ground clearance(full loading) (mm)110124
Turning radius(minimum) (m)5.3
Kerb weight (kg)13261290
Tyre Size195/55R15 85V
Suspension & Brake
Front suspensionIndependent Macpherson strut with coil spring, dual acting tube damper and anti-roll bar
Rear suspensionIndependent multi-link type with cylindrical coil spring, dual-acting tube damper and
anti-roll bar
Rear BrakeDisc
ABS+EBDYes
*A1
المواصفات
Engine1.3L1.1L
Transmission5MT
DriveFF
Engine
Engine code zSQR473FSQR472F
Displacement (cc)12971083
Bore×stroke (mm)73×77.572/66.5
Compression ratio10:019.5:1
Maximum power (Kw/rpm)61/600050/6000
Maximum torque (Nm/rpm)114/3800~450090/3500~4000
Fuel tank capacity (L)43
Maximum speed (km/h)156130
Dimensions & Weight
Length×Width×Height (mm)3700×1578×1527(1564:Optio nal Rack)
Wheelbase (mm)2390
Front tread (mm)1370
Rear tread (mm)1355
Minimum ground clearance(full loading) (mm)124
Turning radius(minimum) (m)4.75
Kerb weight (kg)1040
Tyre Size175/60R14 79H
Suspension & Brake
Rear suspensionSemi-independent trailing arm type with cylindrical coil spring and dual-acting tube damper
Front BrakeDisc
Rear BrakeDrum
ABS+EBDOptional
قديم 02-06-2009, 11:57 AM
الموقع: الشرقيه
قديم 02-06-2009, 12:40 PM
الموقع: الشرقيه
chery/riich G6
Chery Fulwin 2
شوف الكوبيه منها
قديم 02-06-2009, 02:23 PM
مجهود فوق الممتاز يا دكتور ... تسلم ايديك ptmnlo123per171
من تواضع لله رفعه
The ultimate car
would be designed by Italians
engineered by Germans
built by Japanese &
قديم 04-06-2009, 03:34 AM
الموقع: الشرقيه
لاحظ ان بعض السيارات المعروضة والغير موجودة بمصر تمتاز بجودة عاليه من حيث الشكل الخارجى والداخلى والتقفيل والتشطيب النهائى والسؤال الذى يطرح نفسه00
لماذا لاتدخل هذه السيارات مصر؟
هل لان اسعارها ستكون عالية؟
ولماذا تكون عالية؟!!!!!!!!!!!!
هل امتد استيراد البضاعة الصينية الرديئه للسيارات وترك الجيد من اجل مكسب اكبر ام ماذا؟!
احدث موديلات اسبيرانزا, صور اسبرانزا, صور شيرى, شيرى الصينية
الساعة الآن 03:23 AM.
