قديم 06-12-2011, 01:05 PM
الصورة الرمزية haninatoon
haninatoon haninatoon غير متواجد حالياً
التخصص العملى: الهندسة
haninatoon has a brilliant futurehaninatoon has a brilliant futurehaninatoon has a brilliant futurehaninatoon has a brilliant futurehaninatoon has a brilliant futurehaninatoon has a brilliant futurehaninatoon has a brilliant futurehaninatoon has a brilliant futurehaninatoon has a brilliant futurehaninatoon has a brilliant futurehaninatoon has a brilliant future
افتراضي رد: مشكلة غريبه فى زيت الفتيس
http://www.liqui-moly.de/liquimoly/mediendb.nsf/gfx2/4433.jpg/$file/4433.jpg
لاقيتلك الزيت ياعم موجود فى شارع دمشق مصر الجديدة وادى بياناتة ياهندسة
http://www.liqui-moly.de/liquimoly/mediendb.nsf/gfx2/4433%20Hochleistungs-Getriebe%C3%B6l%20GL%204+ %20SAE%2075W-90_EN.pdf/$file/4433%20Hochleistungs-Getriebe%C3%B6l%20GL%204+ %20SAE%2075W-90_EN.pdf
قديم 06-12-2011, 03:19 PM
الصورة الرمزية lost2008
lost2008 lost2008 غير متواجد حالياً
الموقع: cairo
lost2008 has a reputation beyond reputelost2008 has a reputation beyond reputelost2008 has a reputation beyond reputelost2008 has a reputation beyond reputelost2008 has a reputation beyond reputelost2008 has a reputation beyond reputelost2008 has a reputation beyond reputelost2008 has a reputation beyond reputelost2008 has a reputation beyond reputelost2008 has a reputation beyond reputelost2008 has a reputation beyond repute
المشاركة الأصلية كتبت بواسطة haninatoon مشاهدة المشاركة
http://www.mobiloil.com/USA-English/...Gear_Lube.aspx
Question
: Is There a Gear Lube Specific to GL-4?My vehicle is a 1992 Nissan 300zx and requires a single GL4 gear oil in the manual 5-speed synchromesh tranny. Does Mobil make a synthetic gear lube that is a specific GL4? I read on the label of some of the products that the gear oil is applicable for GL3,4 and 5 but have been told that it only applies for differentials and not manual trannies requiring a specific GL5. Is that correct?-- Peter Sushinsky, Orlando, FL
Answer: API GL-5 gear oils can be acceptable for differentials but generally are not recommended for transmissions because a GL-5 gear oil has twice as much Extreme Pressure additive for GL-5 quality gear protection. Even though this EP additive is good for gears it can be aggressive and cause corrosion on the soft yellow metals (brass, copper, bronze) found in the bushings, etc., in manual transmissions.
تصدق عندك حق هو بيقول ممكن استخدامة بس لاينصح بة
بس انا عاوز اتاكد من ان 80W 90 انة API GL 5 مش 4 لانى رميت العلبة وكان زيوت شيل العلبة الحمراء
انا دورت على النت
http://www.epc.shell.com/Docs/GPCDOC...164997_89B.pdf
انا دورت على النت ولاقيت الزيت دة 4 بس زيادة انا النهاردة حوصل شيل بنفسى واشوف العلبة
الشل الاحمر API-GL5 انا كنت اشتريه و رجعته تانى عشان كدة.
سلم الحكم للعسكر و ادى صوته للى معملش الثورة=
قديم 06-12-2011, 03:21 PM
الموقع: cairo
شكرا يا باشا , عرفت سعره كام؟
قديم 06-12-2011, 04:24 PM
ان شاء اللة رايح النهاردة بعد الظهر وحسأل وحأغير الزيت كمان مع انى مشيت بية 1700 كيلو
وعلى فكرة شيل فيها الزيت الصح عبوة 20 ليتر جالون
Shell Spirax S5 ATE (Formerly Shell Transaxle 75w-90) Fully Synthetic High Performance Gear Oil
API Service Classification: GL-4 and GL-5
قديم 06-12-2011, 04:36 PM
mohamed200 mohamed200 غير متواجد حالياً
mohamed200 will become famous soon enoughmohamed200 will become famous soon enough
يا فيرناويه محدتش قالي ليه الزيت القديم منزلش ؟
الساعة الآن 06:12 PM.
