قديم 03-04-2011, 05:25 AM
للاهمية رد: سير الكاتينه
المشاركة الأصلية كتبت بواسطة طارق ابوذيد مشاهدة المشاركة
بسم الله الرحمن الرحيم . بارك الله فيك وذادك علما ولكن رجائى ان تذكر لى اسماء السيارات التى تمشى فى مصر بدون كاتينه ولك جزيل الشكر على معلوماتك القيمه .
v.w brazilia
v.w 1303
Not all car engines have timing belts. Some engine designs have timing chains or a set of timing gears. The purpose is the same, however: to rotate the camshaft(s) in time with the crankshaft.
<CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER><TABLE border=1 align=right height=118><TBODY><TR><TD height=59></TD></TR><TR><TD height=59>Valve timing gears on a Ford Taunus V4 engine
— the small gear is on the crankshaft, the larger
gear is on the camshaft. Since the camshaft gear
is twice the diameter of the crankshaft gear, it
runs at half the crankshaft RPM. See gear ratio.
(The small gear left is on the balance shaft)
</TD></TR></TBODY></TABLE></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER>1996 Ford F-350
</CENTER><CENTER>Ford long block, looking down into the cam gear, you could see the wear pattern on the cam gear.
Very definately a used gear, but it's made out of steeL</CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER>شوف المية على الزيت</CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER></CENTER><CENTER>GIFT 4U</CENTER>
قديم 13-04-2011, 11:29 AM
msmsaas msmsaas غير متواجد حالياً
msmsaas is on a distinguished road
افتراضي رد: سير الكاتينه
السيارة البيك اب الدبابة والنيسان على تروس ولا يوجد سير ام ميتوبيشى بيك اب على سير
قديم 13-04-2011, 03:15 PM
المشاركة الأصلية كتبت بواسطة msmsaas مشاهدة المشاركة
ميتوبيشى بيك اب على2 سير كاتينه!!
البيك اب الدبابة والنيسان على سير كاتينه فى الغالب ايضا !!!بنسبة 95%
: 14369D~149:
قديم 13-04-2011, 10:39 PM
الصورة الرمزية طارق ابوذيد
من انا؟: الشيخ طارق ابوذيد
الموقع: الهرم
بسم الله الحمن الرحيم . هذه السيارات تعمل فقط بدون سير كاتينه ولكنها تعمل بكاتينه اليست تروس الكاتينه موجوده ولكنهما يعشقان فى بعضهما بدلا من وجود سير يربطهما ببعض ولكن عندى سؤال للاستاذ الكريم هل توجد سيارات تمشى بدون كاتينه او تروس كاتينه نهائيا أرجو الافاده ولك جزيل الشكر. السلام عليكم ورحمه الله وبركاته .
قديم 14-04-2011, 01:43 AM
يوجد بدون كاتينه كاوتش او جنزير او تروس كاتينه نهائياولاكن للاسف ليس فى مصر !!!
mazda rx 7
mazda rx 8
: 14369D~149:
الساعة الآن 09:52 PM.
