قديم 19-01-2011, 10:06 AM
اشرف صلاح الدين اشرف صلاح الدين غير متواجد حالياً
اشرف صلاح الدين will become famous soon enoughاشرف صلاح الدين will become famous soon enough
للاهمية لقد وجدت عنوان بخصوص epc في احد المنتديات فهل يستطيع أحد توضيح هذا المعني
position sensor 1 signal voltage 0.08V (normal values for 0.74V).
Because the failure code from reading and Chery Automobile electronic throttle system circuit diagram can analysis: in trouble code in both the accelerator pedal position sensor 1 fault and inlet pressure sensor failure; seen from the circuit diagram, the accelerator pedal position sensor 1 (6, wiring) and intake air pressure sensor (3 wire) 5V reference voltage is determined by the engine control unit, the lines of the fault reason is most likely that the control unit 33 line there is short circuit-breakers or occasionally. So check the engine control unit 33 line and accelerator pedal position sensor 1 and intake air pressure sensor lines.
Finally found this line in the vicinity of the engine control unit, lead by squeezing the shorts. Package after troubleshooting
الساعة الآن 08:49 PM.
